Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I agree with Max Headflow. I had the same problem. I went directly to the ignition switch and found a burnt wire. I takes about 2 minutes to check and not a lot of work involved.
