Need help with noisy Cam
Old Jul 11, 2021 | 04:18 PM
gdishman's Avatar
gdishman
Default Need help with noisy Cam
I have a 2016 Heritage with S&S 583 chain drive cams with stock springs. I really like the low end torque runs great, But I hate that when the engine is warm The valves start rattling. The valve clatters real bad at idle. I have adjusted the valves at all different tensions (from 2.5 turns to 4 turns). Replace lifters 3 times, 2 sets of different push rods, New cam plate, Rocker lockers, Bored out push rod tubes and different oil weights and brands. I am thinking now to just replace the cams. I ride two up 90% of the time and under 3500 rpm. I have the Screamin Eagle air cleaner, D&D fat cat and Tune with power vision with Target Tune. I was looking at the Red line 525 or Woods 222. I have heard good things about Woods 555 but it looks like it is good at mid range. Please help me.
Old Jul 12, 2021 | 10:39 PM
60Gunner's Avatar
60Gunner
Like I told you in your other thread, changing cams will lighten your wallet and that's it. S&S cams are not noisy cams in general. Not like some woods cams that CAN be a little on the noisier side with their more aggressive ramp rates. That said, high lift cams are often noisier in comparison to stock cams anyway.
A video might help.
Old Jul 20, 2021 | 09:48 PM
Since 1968's Avatar
Since 1968
Just a thought, you might try some rocker arm lockers. Maybe it's not your cam ramp profile...
https://www.dkcustomproducts.com/roc...s-dk-rl-tc.htm
Old Jul 21, 2021 | 05:22 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We load the lifter to .140-.150"..... 4.5 turns 32 TPI pushrod.
VERY quiet engine operation with almost any cam regardless of manufacturer......many times quieter than OEM.
Proper oil viscosity per operating temps, per service manual, can go a long way as well.
Scott
quija
Mar 12, 2021 03:28 PM
emperor wurm
Mar 10, 2017 04:41 PM
rsking45
Aug 11, 2014 07:48 AM
mooch78
Dec 13, 2012 02:27 PM
