Break in question
Old Jul 25, 2021 | 01:35 PM
Left Arm Optional's Avatar
Left Arm Optional
6th Gear
Default Break in question
Feeling this is probably a dumb question but... I know new engine break in is important. Don't want to ride too hard or at a constant rate for too long. My questions are: 1. It seems like if you're getting the top end upgraded/redone (new jugs, pistons, etc) seems like you would / should trailer your bike to the shop if not local. How far would be too far to ride back from (assuming constant highway speed)? 2. Supposed to take it easy until thru breaking period. Videos I've seen of dyno runs seem pretty intense. Are they short enough to not damage the engine or should they be done (tuning) after break in?
Old Jul 25, 2021 | 01:48 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If the work is not done until the bike is at the shop why does it matter how far you ride it?
Does it matter what speed you do on any particular road? My bike first 50 miles do not exceed 3000 rpm. That sees me doing around 60 mph in 5th.
I have read about some doing a few minute run heat cycles but I bought my bike brand new and rode 35 miles home without stopping.
Old Jul 25, 2021 | 04:45 PM
Left Arm Optional
6th Gear
Due to the return trip... For example, Zippers is down near Baltimore which would be a 6hr ride. Would riding it back as opposed to trailering it lead to any issues?
Old Jul 26, 2021 | 03:12 AM
Andy from Sandy
What is the mileage, break ins are not usually measured in time? I doubt that is a problem, you just need to follow the rule of varying the engine speed without labouring the engine and avoid excess high throttle openings so get up to speed at a slower pace.
What distance is specified to first oil change? Mine was 1000 miles.
Maybe on a DIY job you would check everything after a few miles but I didn't check any fasteners on the engine as there was no leaks or odd running behaviour.
Old Jul 26, 2021 | 12:18 PM
Clammy's Avatar
Clammy
There are lots of suggested break-in methods out there, so it can get confusing determining which one to use.
I've used the following break-in method on the last 2 top ends done on Reaper (first one my the local dealership in 2013, and I did the second one myself last summer). I got just under 100,000 miles on the dealership build before having to do the top end last summer, and I have almost 20,000 on the current top end. Reaper used/uses almost no oil, makes a ton of power, and has longevity. I don't beat on her, but I regularly twist the throttle, and hit the red-line, so I'm not a grandpa rider either. I will always use this method for break-ins in the future:
1) Do not start the engine until you are ready to ride the bike.
2) After starting, quickly get out on the road and into third gear.
3) Accelerate at full throttle from 30 to 60 mph in third gear.
4) Close the throttle and coast back to 30 mph.
5) Repeat this full throttle/coast procedure a total of 10 times.
6) The rings are now seated and you can ride normally.
Cheers!
Old Jul 26, 2021 | 02:29 PM
hrdtail78's Avatar
hrdtail78
From lift to dyno for break in and dyno tune. I tell my customers to ride em like they are stolen when they leave. Change oil when they get home if they didn't have me do it. Zippers is also a one stop shop.
Old Jul 26, 2021 | 09:23 PM
NODYNA's Avatar
NODYNA
Distance is not the limiting factor. As others have said just vary the engine speed. On my new bike break ins I'll take every exit as an opportunity to down shift and accelerate back to speed. If the exits are more than 10 miles apart when traffic allows I slow to 10-30mph then accelerate back to speed. Pull off the road if necessary not to hard to vary engine speed if you work at it.
Old Jul 26, 2021 | 09:30 PM
marcodarq's Avatar
marcodarq
i second the direction to have Zippers break it in on the dyno when they tune it, should be no problem.
m
Old Jul 27, 2021 | 03:50 PM
djl's Avatar
djl
m
ramsay_za
Exhaust System Topics
18
Nov 30, 2013 06:20 PM
SafetyMan
Nov 13, 2013 04:04 PM
Matt990724
Jul 11, 2012 09:41 PM
dynalowride
Mar 12, 2007 02:49 AM
PoleCat
May 14, 2006 07:45 PM
