Damaged Crank Position sensor
Old Jul 31, 2021 | 12:28 PM
DRB Harley's Avatar
DRB Harley
5th Gear
Default Damaged Crank Position sensor
I am new to the forum and was wondering if anyone can tell me what would cause my Crank position sensor to be damaged on the end thats inside the case? I have a 2006 CVOUltraClassicFLHTCUSE. Any help would be appreciated.
Old Jul 31, 2021 | 12:35 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!!
Old Jul 31, 2021 | 12:38 PM
Dseago1969's Avatar
Dseago1969
I’m guessing warped crankshaft/flywheel problem. Unfortunately your probably looking at a rebuild or replacement on the engine.
Old Jul 31, 2021 | 12:47 PM
BuzzCap7's Avatar
BuzzCap7
Old Jul 31, 2021 | 12:55 PM
WP50's Avatar
WP50
Originally Posted by DRB Harley
what would cause my Crank position sensor to be damaged on the end thats inside the case? .
Well I can't think of something that would not require taking some things apart.
Did it cause the bike to quit running?
Any chance of a pic of the sensor?
Why did you pull the sensor ?
WP
Opps Most around here appreciate you making an intro in the Welcome Area too
Old Jul 31, 2021 | 01:52 PM
Dseago1969's Avatar
Dseago1969
Most around here don’t look at the welcome are actually.
Old Jul 31, 2021 | 02:19 PM
BuzzCap7's Avatar
BuzzCap7
Old Jul 31, 2021 | 02:21 PM
TracerBullet's Avatar
TracerBullet
Welcome aboard
Old Jul 31, 2021 | 02:49 PM
DRB Harley's Avatar
DRB Harley
5th Gear
Thanks.
Old Jul 31, 2021 | 03:03 PM
DRB Harley's Avatar
DRB Harley
5th Gear
Default Crank positioner
To answer the earlier question the bike started once and would not start again and I checked the codes and it said the sensor was bad so I pulled out to find out it looked like thid.
