99 Softail High Compression When Hot
Old Aug 24, 2021 | 08:29 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by wfolarry
Lifters bleeding down when hot could be the cause.
I thought I mentioned that but must have been another thread.. but valid point....
Old Aug 24, 2021 | 09:21 AM
Highwayman99's Avatar
Highwayman99
OK that is something to check, thanks!
Old Aug 24, 2021 | 07:54 PM
Highwayman99
I haven't had a chance to look at this yet but I thought that I should also mention since you brought up lifters that I have adjustable pushrods. I am not hearing them rattling so I don't think that they are loose.
Old Aug 25, 2021 | 07:00 AM
bustert's Avatar
bustert
do not think the lifters are the issue. all lifters bleed down but if adjusted correctly has nill effects especially at cranking rpm.
you did not mention how the starter sounds as it is cranking.
timing as mentioned is a likely suspect.
Old Aug 25, 2021 | 07:02 AM
wfolarry's Avatar
wfolarry
Wrong.
Old Aug 26, 2021 | 08:28 AM
bustert's Avatar
bustert
one very important fact you are not considering mr. w is:
cranking speed. there is way more time for the cyls to fill so it is nearly a full fill but as rpm increases, time reduces and you get a partial fill.
if it is as you say, then engines since the first hyd lifter was used would have issues and down to this day.
will there be diff, why sure, but, as i said, nill effects, aka, nothing to worry about and cannot be corrected unless you go solids!
now if you talk running rpm, then there will be bigger issues.
Old Aug 26, 2021 | 08:47 AM
fat00boy's Avatar
fat00boy
When the intake valve closes determines how much the cylinder fills not the cranking speed
Old Aug 26, 2021 | 09:37 AM
98hotrodfatboy
Technically, the ivc close determines the effect stroke of the Piston in the cylinder.... The latter the ivc the shorter the effective stroke...
Old Aug 26, 2021 | 09:49 AM
Highwayman99
Just to make sure this is related to the issue I am having the problem of the starter having an issue to crank the motor only occurs when the motor is hot after a long run and the restart is attempted within 15 or 20 minutes of shutting off the motor. If the bike sits for an hour or so then I never have an issue with the starter struggling.
Old Aug 26, 2021 | 09:52 AM
Max Headflow's Avatar
Max Headflow
While the leaky lifter is good, and ignition timing off another, I suspect that the 3rd could simply be weak battery. It's probably worth going through the cables and make sure they are up to snuff and making good contact. It's a vibratory softail so even loose terminals could cause the issue.
