Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Need some help guys I have a 2005 road king 88 with 20000 miles on her I installed new cam shafts cam plate high flow oil pump .
Now I decided to put the S/E 95 big bore kit in got it all together changed oil ran the bike once up to operating temp I get A knock
sounds like its in the rear jug? Only when warm if I throttle the bike the noise goes away Im at a loss any ideas? Please help!!
oh yeah compression is good motor runs perfect !
Need more info. What cams, lifters, push rods and adjustment if applicable, etc.
You say you did a 95 bore and took it for a ride...I assume you did heat cycles and break in miles? Or broke in on a dyno first? A video of it running making the noise would sure help.
It has 203 cams adjustable push rods S/E lifters ! I put the motor back together and started it on the rack as soon as it got warm is when I heard the new sound . Bike never left the rack I shut it down let it cool and restarted once back to operating temp the knock came back I can try and post a video when I get back to the shop
Bike still on rack with the same noise once it gets warm!! I did a comp test both jugs at 175 I just can’t figure it out I even changed the lifters just to be sure re did the adjustable push rods 4 times has perfect oil pressure runs great until hot ! I do not know how to post the sound clip I took of it running please help
The head gasket has me thinking I did put the cometic head gaskets on it and they are way thicker so you think I should tear it back down inspect it and put the hd head gaskets on it
What was your piston to cylinder wall clearance..? according to the video it sounds like a tight piston when hot.. Check the cylinder wall for scuffing.. You can purchase a bore scope pretty cheap today...
