Engine Knock
Old Mar 9, 2022 | 04:10 PM
Oghenny's Avatar
Oghenny
I’ve checked the push rods several times before tearing it down because I thought the same thing ! Now that it is a part I am going to mic every thing and see what clearances are will post back thanks for all the input
Old Mar 9, 2022 | 05:25 PM
Max Headflow's Avatar
Max Headflow
Well, maybe you got a bad lifter?
Are you sure the cam timing is right?
Old Mar 9, 2022 | 05:29 PM
Oghenny's Avatar
Oghenny
I’ll start from the beginning early summer I replaced everything in the cam chest with all screaming eagle parts 203 cams rode all summer no issues this winter I did the 95 inch jugs and pistons that’s when the noise started ! I replaced the lifters before the tear down once motor got hot noise came back now I’m back to square one cam chest out bike completely tore down! I see no damage anywhere except the scoring in cylinders and ring gaps lining up not sure where to go from here
Old Mar 10, 2022 | 05:55 AM
98hotrodfatboy's Avatar
98hotrodfatboy
At this point with the motor totally torn down take your cylinders and pistons to a local Indy machine shop and have them measure up the Pistons and cylinders to make sure the Pistons have the proper fit.. As I stated before you need torque plates to properly check the cylinders.. At the least you will eliminate this part out of the equation...
Old Mar 10, 2022 | 08:57 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Like Max said in post #4 then later in the thread, are you sure you had the pistons in correctly, meaning the arrows point to the intake side. If thats the case then the arrows should be pointing to the center of the engine/intake manifold. I would guess because the intake valve is of larger diameter than exhaust, that intake valve would then be hitting the outside edge of the exhaust valve relief if the piston was installed backwards. Not to be a jerk but did you really check them?
Ride safe!
Old Mar 10, 2022 | 10:02 AM
Oghenny's Avatar
Oghenny
There both pointed forward
Old Mar 10, 2022 | 10:44 AM
nutsandbolts5212
Ok so measure those valve reliefs and the larger one goes toward the center, small to outside. If I'm correct, that front piston is installed backward. LMK
Ride safe!
Old Mar 10, 2022 | 10:51 AM
brakeless's Avatar
brakeless
Ride safe!
OP says both arrows point forward.
Old Mar 10, 2022 | 11:00 AM
Max Headflow
Ride safe!
It's not.. They both need to point forward as the reason for the arrow is to ensure piston offset not valve relief.
From a 2001 SM.
4. See Figure 3-29. Place piston over rod end so that the
arrow stamped at the top of the piston points toward the
front of the engine.
Old Mar 10, 2022 | 11:26 AM
nutsandbolts5212
From a 2001 SM.
I stand corrected, thank you Max.
Ride safe!
