Engine Tick and Pushrods...
Old Mar 13, 2022 | 10:33 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not sure which bike but lifter travel has nothing to do with pumping oil to the top end on TCs. I suspect the same for EVOs but I've really not had Evo lifters a part. On TCs, the oil is metered through the lifter cup which is fed oil directly from the oil passage. I've set lifters deep in the travel all the time. It keeps them from collapsing too much at high Rs. Now if you pulled rockers out of the towers and failed to apply plenty of lube they'll run dry for a while a while before any oil gets to the top end. Had a buddy that failed to do that on a TC, Went for a short ride, When he cam back the rockers were squeaking. Did you make sure that pushrod holes were cleared?
****.... Rookie mistake.... Never checked for clear oil passages... Damn.....
Old Apr 5, 2022 | 05:37 PM
98hotrodfatboy
So to update and close out this thread. I didn't like the way the cam was performing in this last build. My Woods 6EXP cam totally different grind then the 3Suns cam and the motor just really didn't perform too well so I put the 3Suns came back in went back to the adjustable pushrods and cut my inner push rod tubes shorter to alleviate any chance of hitting and everything's together and running great... So wasting $100 on Maton's pushrods no big deal.. Lesson learned.. There last couple of weeks with my Wego III, I was able to get the motor dialed in very well and must say this bike runs like a raped ape ... Feels good to have it back and yes the valve train is pretty quiet so all good now.. Now I just have to learn to leave it alone.... Lol...
Old Apr 5, 2022 | 05:45 PM
brakeless's Avatar
brakeless
Yeah, well see how long "leaving it alone" will last. LOL! And just for the record, I've never seen a raped ape. Just hearsay I guess. I asked around and nobody else has seen one either!
Old Apr 5, 2022 | 06:22 PM
98hotrodfatboy
That's because they're so ****ing fast......
Old Apr 5, 2022 | 06:24 PM
brakeless's Avatar
brakeless
Well obviously not faster than whatever is raping them!
Old Apr 5, 2022 | 06:25 PM
brakeless's Avatar
brakeless
Maybe the saying should be "Faster than a raped apes's rapist!"
Old May 27, 2022 | 02:49 PM
Threeleggedog's Avatar
Threeleggedog
Does anyone use Vernier calipers anymore? Like I mentioned in the other tread, Smiths tapered adjustables are pretty good. I run them in my 131.. Switch over to them from SnS 7/16 on my 116 and they were quieter. 131 has a 640 cam, 116 had a 625,, Well see how they do in the 107 with a 9B...
My battery died in mine....
rhaines751
EVO
Jan 5, 2020 02:37 PM
Uncle G.
EVO
Apr 15, 2014 07:11 PM
zimm
EVO
16
Mar 3, 2014 07:44 AM
Pinetop
EVO
32
Nov 11, 2012 09:43 PM
PakMul
Engine Mechanical Topics
Sep 19, 2010 11:02 AM
