Foot lbs or Pound ft = torque?
Old Apr 23, 2022 | 08:01 PM
  #101
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Well if your going to get into it, then one needs to know if it's measure in SAE, STD, DIN ect. and on a DynoJet , SuperFlow, Mustang ect as they all use various Fudge factors just like changing the size and shape of the picture screws the way it looks.
Old Apr 23, 2022 | 08:36 PM
  #102
IdahoHacker's Avatar
IdahoHacker
Yup. If you just go from SAE to metric, the numbers on both axes change completely, and are now completely different, even though the graph stays exactly the same.
Old Apr 23, 2022 | 09:30 PM
  #103
60Gunner's Avatar
60Gunner
While those can/do affect actual numbers, they don't change the whole 5252 equation tho.
But since you bring it up, there's some misconceptions with the sae/std thing too. The difference isn't always all that much and SOMETIMES sae can be higher than std.
The difference in dynos is out of my league except I know there are differences.
​​​​​​STD for the same run in my case was 130/129. A difference of 3/3.
Old Apr 23, 2022 | 09:31 PM
  #104
IdahoHacker
My understanding is that the difference between SAE and STD is around 3%-4%, depending.
Old Apr 23, 2022 | 09:51 PM
  #105
Ed Ramberger's Avatar
Ed Ramberger
Steve - now you have opened a whole new can of worms! This is where we get to tell people that have their graphs in STD that they might be a little sad when graphed in SAE.
In dyno class I used to graph the same run in all the different correction factors and ask which was the best. 99.9% of the people looked at lines and didn't read data -hence they didn't realize it was the same run presented in different factors.
Old Apr 24, 2022 | 07:34 AM
  #106
60Gunner's Avatar
60Gunner
Correction factors are there to actually "level the playing field" so to speak under varying conditions. Unfortunately they can also be used for less legitimate purposes to boost numbers.
I know I'm not telling some of you anything new.
​​​​​​I think the SAE/STD difference is a little more complicated than just a difference of a set % but the 3 - 4% is probably pretty close a lot of times. What conditions would actually make SAE numbers larger than STD I can't really explain either. Not precisely anyway. It was explained to me at one time years ago but I'm not sure how to explain it. It has to do with conditions like temp, humidity, altitude, etc. There are times, conditions, etc. where STD is more of an accurate representation of what's being produced power wise than SAE tho.
The closer actual conditions are to that used by SAE the closer the two will be is how I understand it.
Based on actual conditions at the time, mine was 130/129. But based on a certain set of conditions SAE uses it was 127/126. So which is actually an accurate representation? Not so simple I say. What makes SAE "right" and STD "wrong"?
Came across this explanation.
Simple, SAE is a prediction of what your HP/torque will be at a certain, accepted weather conditon. STD is what your car is actually putting out right at that exact moment.
STD numbers will be higher if the conditions are better than SAE (ie colder, less humid, high pressure), and conversely lower when the conditions are worse than SAE.
Old Apr 24, 2022 | 09:04 AM
  #107
Max Headflow's Avatar
Max Headflow
This shows little you really know about what they represent..
SAE:
"SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque.
STD:
STD is Another power correction standard determined by the SAE. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C)."
Under these conditions STD will always produce more power. STD defines both higher pressure and lower temp as run conditions to correct to which means denser air. Denser air means more power. Any condition where the SAE is produces more will not be related to the definition. This is simple physics.
"STD power" is "not actual" "Actual power" is "actual power" Now actual power can be higher or lower than corrected temps like STD and SAE depending on ambient conditions.
Where do you get this information from?
Old Apr 24, 2022 | 09:24 AM
  #108
60Gunner's Avatar
60Gunner
I said it's something I just came across for the sake of discussion. How accurate it is I don't know. But what makes one right and one wrong based on actual conditions vs a set of predetermined conditions?
I don't know. That's why I post both. The difference between them was more like 2%.
​​​​​So one uses a lower temp, humidity, etc. standard than the other? But both use these correction standards?
What's the difference between dynos and what makes one more right than the other?
Old Apr 24, 2022 | 10:23 AM
  #109
billgran's Avatar
billgran
Here are my notes from training days in the outboard motor business. Years back in my younger days I ran dynos while at OMC Engineering, makers of Johnson and Evinrude outboards. Today the industry uses ISO or ICOMIA dyno procedures.
There are two main correction factors used to standardize results with varying
atmospheric conditions: SAE J-1349, which adjusts the prevailing
test conditions to 77 degrees F and 29.92 in-Hg of barometric
pressure; and SAE J-607 (also known as Standard Temperature
and Pressure or STP for short), which corrects the test data to 60
degrees F and 29.23 in-Hg of barometric pressure.
Most of the OEM manufacturers use SAE J-1349 to rate engine power output,
measured at the flywheel. Most magazines, race engine builders and
aftermarket companies use SAE J-607 STP correction factors when
quoting dynamometer horsepower figures. The difference between the
two correction factors is generally 5 percent as a result of the STP factor
having a colder air correction factor.
ICOMIA Standard No. 28-83
Power measurements and declarations for
marine propulsion engines and propulsion systems
ISO – International Organization of Standards
• ISO 3046/1 -- Reciprocating Internal Combustion Engines:
o Performance--Part 1: Standard Reference Conditions and Declarations of Power, Fuel Consumption
• ISO 3046/2 -- Reciprocating Internal Combustion Engines:
o Performance--Part 2: Test Methods
• ISO 3046/3 -- Reciprocating Internal Combustion Engines:
o Performance--Part 3: Test Measurements
Old Apr 24, 2022 | 10:38 AM
  #110
60Gunner's Avatar
60Gunner
What determines the difference between them percentage wise if not the actual temps, humidity, etc.?
I had a difference of 2.3%.
​​​​​​is it true uncorrected is never accepted? If so, why? Does it result in higher or lower numbers?
Thanks. I'm trying to understand why one is considered more accurate in ALL circumstances.
