Lifter Noise?
Old Jun 21, 2022 | 11:32 AM
Lunchboxx's Avatar
Lunchboxx
Default Lifter Noise?
So I notice when I start my bike especially when is cold in the morning, I hears this Clack clack clack and then it goes away. 2016 CVO ultra limited. Is that the lifters and should I get S7S lifters and adjustable Push rods?
Thanks
Old Jun 21, 2022 | 12:58 PM
wethead103's Avatar
wethead103
I have a 2016 ultra cvo, just did the s&s lifters and adjustable pushrods. I recommend doing them asap. Not sure how many miles you have on your bike but if you have around 20k or more its time to do them. I had one lifter that was going bad and it would tick. Its not a hard job if you have any mechanical experience. Lot’s of videos on you tube. Good luck.
Old Jun 21, 2022 | 03:21 PM
djl's Avatar
djl
Originally Posted by Lunchboxx
So I notice when I start my bike especially when is cold in the morning, I hears this Clack clack clack and then it goes away. 2016 CVO ultra limited. Is that the lifters and should I get S7S lifters and adjustable Push rods?Thanks
If the noise goes away at operating temps, it's just the OEM lifters that have leaked down pumping up; no harm. Having said that,if the lifters are OEM, probably a good idea to replace them with Johnson HyLifts from WFO Larry since there have been some issues with the OEM lifters.
http://www.larrysmotorcyclemachine.com/lifters.html
There are three styles; standard, slow leak down and slow leak down with pin oiling; 2313; 2313S and 2313SE. The 2313S should be fine. Swap out the lifters, run it for a while and if the noise is gone, no need for adjustable push rods.
Old Jun 21, 2022 | 05:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Old Jun 22, 2022 | 03:43 AM
tpb857's Avatar
tpb857
My 2016 CVO Street Glide does that and it stops as soon as it gets up to operating temperature. 9k miles on the bike. I was going to wait until 15-20k and change the lifters just for peace of mind, but I decided to trade it in. My 14 CVO Limited did it too.
Old Jun 25, 2022 | 10:32 AM
Screamin beagle's Avatar
Screamin beagle
Well known issue with the hd stock lifters that is made worse by the heavy valve springs in the 110 heads. I wouldn't wait for xx amount of miles...just change them asap. Very cheap compared to a bad lifter wiping out the whole motor. The hylifts by wfoLarry are great lifters and a good price too. Any quality aftermarket lifter from a known source is the way to go...and adjustable pushrods make the job easier and easier for any future trips into the cam chest. Don't wait.
Old Jun 25, 2022 | 09:36 PM
Max Headflow's Avatar
Max Headflow
Being a 2016, it has 99C lifters in it.. I'd remove them as soon as possible.. DJL's rec is a good one. WFO is my go to guy for lifters. SnS gets them from the same place..
Old Jun 26, 2022 | 06:14 AM
Steve Sportster's Avatar
Steve Sportster
Thanks
I have the same problem with my 2018 FLHCS (Heritage 114). 29k miles. Advice?
Old Jun 26, 2022 | 03:58 PM
djl's Avatar
djl
Question asked and answered. Johnson Hy-Lifts; one of the three available configurations depending on build; any one of the three is a much better option than OEM.
Beeinbad2
Sep 5, 2018 01:59 PM
nhcopley
Screamin Eagle CVO Models
23
Nov 23, 2014 09:27 PM
bigpop
Aug 10, 2012 07:16 PM
Harsh1828
Jul 29, 2012 09:55 PM
flattracker60
Jun 8, 2011 12:39 AM
