Leolion59
Old Jul 12, 2022 | 08:07 PM
LEOLION59's Avatar
LEOLION59
Stage I
Thumbs up Leolion59
I have a 2008 DYNA STREET BOB after my 7th spinal I messed up and let it set up in my barn with the trash fuel i have changed fuel pump,reg,filter as well as rebuilt the quick connector cranks but wont start ...I am a 62 yo die hard PATRIOT FREEDOM FIGHTER disabled but will ride till I die if GOD WILLS... I need some help ..I checked all fuses got fire but refuses to start I do appreciate you Brothers and Sister bikers...BE SAFE RIDE FREE.......PEACE PEOPLE
Old Jul 13, 2022 | 08:12 AM
roussfam's Avatar
roussfam
What's a Patriot Freedom Fighter?
Old Jul 13, 2022 | 08:25 AM
Max Headflow's Avatar
Max Headflow
Check the fuel pressure.. You can try squirting a little gas into the intake to see if it will pop over.
Old Jul 13, 2022 | 11:39 AM
nevil's Avatar
nevil
Check for codes.
Also look in the tank when priming the fuel pump, leaks are common with bikes that old. The less gas in the tank, the better chance of seeing or hearing gas hitting the inside wall.
Old Jul 13, 2022 | 03:04 PM
mskirwin's Avatar
mskirwin
You don’t say if it’s fuel injected or carb’d If is carb’d you should be able to put a small amount of fuel and see if it starts. If it’s injected can you hear the fuel pump prime when turning the run switch on?
Welcome from Philadelphia, enjoy the ride.
Old Jul 13, 2022 | 05:55 PM
TracerBullet's Avatar
TracerBullet
Welcome to the forum
Jefftatum1991
May 10, 2022 11:32 AM
Mario Velez
Aug 1, 2019 11:43 AM
Tyroidll
Feb 9, 2014 12:11 PM
sideshow bob
Jun 28, 2010 10:20 PM
HDCHROME110
Jun 21, 2008 12:41 PM
