In depth discussion on 88 swap
Old Jul 23, 2022 | 10:45 AM
huey_da_jugg666's Avatar
huey_da_jugg666
5th Gear
Default In depth discussion on 88 swap
I’ve got 2 fat boys , an 08 with the 96 and a 03 with an 88 , you know where I’m going with this already . I want to swap the engines and trannys , but this is my first go around so I want to make sure this will work before I even go through the motions . I know the 08 has a wider frame , that being said will I have to swap anything else aside from the engine and trans?
Old Jul 24, 2022 | 05:42 PM
Max Headflow's Avatar
Max Headflow
I've not tried this but you'll have to swap the whole drivetrain. In other words, engine, tranny and primary. I suspect that it might work as this same can be done with baggers.
huey_da_jugg666
Twin Cam Motors
Jul 13, 2022 09:03 PM
Kyle Moore
Milwaukee Eight (M8)
Oct 15, 2018 09:25 PM
paco
May 12, 2018 11:26 PM
forbidden
Jan 2, 2013 07:55 AM
jddrouin
Oct 27, 2008 08:44 AM
