Will it fit / work ? 103 in a 99 frame
Old Nov 9, 2010 | 03:10 PM
paco's Avatar
paco
Default Will it fit / work ? 103 in a 99 frame
Hello all,
Found a 103" engine out of a 08 FLHP. I have a 95" in my 99 FLH eglide. has anyone swapped an 08 engine into a 99-07 frame with a 5 sp. tranny ? if so, were there any problems or issues ?
thanks in advance for any help.
Old Nov 9, 2010 | 04:40 PM
Mike's Avatar
Mike
The motor mounts were moved for the 96 motor.
For some reason I'm thinking there's clearance issues with the motor being taller, but I can't for the life of me figure out why that might be.
Old Nov 9, 2010 | 04:47 PM
user 8373900's Avatar
user 8373900
The only outer difference I can think of, is the top adjustable mount was moved in 08 to accommodate the 6 gallon tank. As far as the ECM and other stuff you may need to purchase to make the new engine run, is different than your 99.The 96 is just an 88 with a few different internal parts.
Old Nov 9, 2010 | 07:15 PM
speakerfritz's Avatar
speakerfritz
I'd save the trouble and just put 103 heads on. The casting for 88's, 96's, and 103's are cut from the same jug.
Old Nov 9, 2010 | 11:02 PM
CT-Bagger's Avatar
CT-Bagger
Should fit.
Old Nov 10, 2010 | 05:20 AM
inverse121's Avatar
inverse121
I keep hearing it can be done, but I wish I knew someone that has done it and could post some pics. It seems there is an abundance of 07+ take out 96s and 103s lately.
Old Nov 10, 2010 | 05:22 AM
DrPlastic's Avatar
DrPlastic
Could try posting in the engine forum too
Old Nov 10, 2010 | 05:41 AM
mtclassic's Avatar
mtclassic
With massive amounts of money anything is possible, but this is not feasable. Tranny to motor is completely diff on the 96" vs 88"
Old Nov 10, 2010 | 05:51 AM
inverse121's Avatar
inverse121
MT, what if you get the entire assembly?
Motor, tranny, primary, everything...
Old Nov 10, 2010 | 05:55 AM
mtclassic's Avatar
mtclassic
If you have the ability to fabricate and lots of money anything is possible but lots of obsticles.
