Balancing piston weights
Old Aug 7, 2022 | 06:04 PM
Max Headflow's Avatar
Max Headflow
Now you know why many of us avoid SE parts. HD close enough it will do.
When I bored my 96 to 103, I used stock 103 pistons..
Old Aug 8, 2022 | 10:55 AM
PureHybrid's Avatar
PureHybrid
Originally Posted by Crankee Yankee
are you comparing complete assemblies or just pistons?.. 7+grams seems excessive. I'm used to 2-3 typically unless they're S&S pistons w clearance cut in rear only but, even those are closer than that... you might try measuring both pistons to be sure that one isn't an o.s. while odd, I wouldn't let it stop me. the pistons factor into the balance plot at 60% & that's a total weight divided by 2 ( f&r).. if you feel you must remove material, tread lightly. both cast & forged pistons are processed under pressure for stability sake, removing material from underboss @ w/p can relax the material losing the taper & sizing.. measure both before you start. & after.. if you can't wrap your head around my advice, think about this, the rear rod weighs about 65lbs more than the f-rod. if you feel you need to take corrective action , install lighter piston on the heavier rod...
Easy on the doom and gloom pal.
In your world nothing would have to be weight matched, but this is life. Nothing is perfect, especially castings. Removal of material from an area that literally every engine builder uses (as well as MFGs recommend) causing an issue is fantasy.
Not sure what to make of your "processed under pressure" comment. I suppose machining the dome or valve relief on a piston would affect the ring land concentricity too then...
Old Aug 19, 2022 | 03:55 AM
Crankee Yankee's Avatar
Crankee Yankee
6th Gear
ive searched the thread & couldnt find one sunscriber that asked you to make anything of my "processed under pressure" comment.. our loss i guess... i was.just tryna help someone here as i have some experience with the.issue at hand.
i wont make that mistake again..
Old Aug 19, 2022 | 09:39 PM
Harley1004's Avatar
Harley1004
Default Thread on hold!
I will do everything in my power to give the outcome of this thread. Like I said, it’s gonna be a little while, I have faith it’s going to be a good build.
Old Sep 14, 2022 | 09:28 PM
Harley1004's Avatar
Harley1004
Well, the verdict is in.
I had a very close friend of mine run the first 120 mile break in on the new topend. I would’ve done it myself, but I just finished with the neck surgery and I was in a neck brace, I mean I am in a neck brace.
My friend is has owned multiple Harleys throughout the years. He told me that it was one of the smoothest running motors with little to no vibration that he’s driven in a Harley Davidson.
So, I guess balancing piston weight was a good idea.
I will pick up this thread in 2023, after I get to put a few thousand miles on the bike next year. Until then
Knowledge is power……..
Old Jun 14, 2023 | 12:48 AM
Harley1004's Avatar
Harley1004
Runs quiet on 25w-60 spectro
oil.
Jamied
Milwaukee Eight (M8)
Nov 26, 2021 09:56 PM
THE WEIAND ONE
General Topics/Tech Tips
Nov 20, 2015 06:39 AM
cajun1957a
Shovelhead
Oct 18, 2014 09:41 PM
1sweetglide08
Jan 2, 2013 11:21 PM
Bad Disposition
Exhaust System Topics
Apr 18, 2009 02:27 PM
