new rods.
Old Oct 14, 2022 | 06:19 PM
paud's Avatar
paud
Default new rods.
Hey all
Installed new cam and installing new adjustable push rods. Got two in, looks good. Put in other two and after 15 minute bleed down, I could not turn one rod by hand so decided to start over with those two rods. In doing so, do I need to do something to the tappets to get them to bleed down again?
Old Oct 14, 2022 | 07:08 PM
djl's Avatar
djl
What lifters and pushrods are you using? What is the procedure you are using to adjust the push rods? TDC on compression stroke? Using the correct TPI for the pushrod? Is this your first time? Some get the procedure wrong, take too many turns and bottom out the lifter travel. Provide more information.
No disrespect; but more information would help.
Old Oct 14, 2022 | 07:23 PM
paud's Avatar
paud
stock lifters, SE pushrods with new torque cam. I was following the procedure on a video made by J&P. At the same time I was reading the instructions that came with the adjustable pushrods.It is not my first time but it has been a number of years since I did the first one.
Old Oct 14, 2022 | 07:41 PM
Screamin beagle's Avatar
Screamin beagle
After the first two bled down did you then roll the engine over to TDC compression stroke for the next cylinder?
Old Oct 14, 2022 | 07:50 PM
paud's Avatar
paud
I thought I did but....now I think I might have been off.
Old Oct 15, 2022 | 11:10 AM
djl's Avatar
djl
What I did not see in the video was getting cams on the base circle ON THE COMPRESSION STROKE. Back everything off, let the lifters reset and start over from the beginning with the pistons at TDC on the compression stroke.
Old Oct 15, 2022 | 04:36 PM
paud's Avatar
paud
Here is where I need some input. I can insert but not tighten the push rods to make it easier for me to see the up and down of the lifters. No sure how to figure IF I am on the compression stroke.
Old Oct 15, 2022 | 08:10 PM
Since 1968's Avatar
Since 1968
I have found it helpful to put a zip tie on each pushrod. Makes for a solid confirmation on their movement while spinning the rear wheel. (I think the next time I do this I'll pull the timing cover and put a wrench on the crank sprocket nut, so much easier.) The other thing I've done after doubting myself on the cam position is to focus on just one pushrod. Turn the engine over and find the lowest lift point for that pushrod. Turn the engine both ways and confirm where the pushrod starts to lift. Split the difference and you are on the heel of the cam. Follow the pushrod manufacturer's procedure to set the preload and move on to the next one. Takes more time, lots more engine turning, not the way the pros do it, but I've got the time....
Old Oct 15, 2022 | 08:21 PM
paud's Avatar
paud
I was thinking of doing ONE push rod at a time, like you 1968 mentioned. Easy to find the bottom that way....
Old Oct 15, 2022 | 08:37 PM
Since 1968's Avatar
Since 1968
Yeah, I struggled a bit to absolutely confirm I had a piston on TDC. I put a narrow steel rod down the spark plug hole but the valves grabbed it. I tried a straw and it got ripped up. I tried a small bamboo shoot and it got cut off. When I started the bike later on I had a flaming bit of bamboo shoot out the exhaust and the whole garage smelt like I was burning incense....
