Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
UPDATE: I replaced my stock battery cables with Sumax 2 gauge cables. I did not see anything wrong with the stock cables nor did I see any evidence of loctite.
RESULT: the bike fires RIGHT up. I've never seen it start this well, even stock. Even with a crankcase full of oil the starter didn't struggle one bit. It was sitting for about a week and I couldn't start it before swapping cables. Thank you for everyone's suggestions!!!
