Machining cylinder base.
Old Nov 22, 2022 | 07:45 PM
wilburbill's Avatar
wilburbill
Default Machining cylinder base.
So when machining cylinders to correct deck height it like looks like most machine shops clamp off the bore. Is there any danger of damaging a fresh bore job by doing this?
Old Nov 23, 2022 | 06:59 AM
wfolarry's Avatar
wfolarry
Put soft pads on the chuck jaws & problem solved.
Old Nov 23, 2022 | 01:09 PM
Max Headflow's Avatar
Max Headflow
Couple of points.
I'd be real careful if grabbing the bottom. I'll use soft jaws if the spigot is thick enough.. The rest of the times, I set the cylinder on a Tq plate and use the mill.
If grabbing at the top (better), make sure that the cylinder is centered along the axis. Run the indicator down the bore with the cylinder clocked in different positions. You may find that the bottoms aren't flat.
Scottie p
Flathead
Aug 11, 2022 08:42 AM
thefactory
Twin Cam Motors
May 18, 2021 12:26 PM
Roadkill73
Jan 19, 2014 10:45 PM
laserman2431
Jul 17, 2012 09:01 PM
El Chiguete
Feb 21, 2011 02:05 PM
