Pushrod adjustment
Old May 22, 2023 | 03:18 PM
  #41
paud's Avatar
paud
You sure it's TDC compression?
For the most recent adjustment, yes. I had the cam cover off. I have not gone back in to check it though. With the cam cover ON, I remove 2 spark plugs, put the bike in 6th gear, and rotate the rear wheel. I watch the pushrods move, etc.
Old May 22, 2023 | 04:00 PM
  #42
Max Headflow's Avatar
Max Headflow
So the back pushrods were moving when you bumped the front to TDC?
Old May 22, 2023 | 05:12 PM
  #43
paud's Avatar
paud
essentially. TDCC, both rods are down, piston is moving up, and air rushing from spark plug hole. With a straw, or thin stick in spk plug hole, observe piston position...
Old May 22, 2023 | 05:48 PM
  #44
djl's Avatar
djl
Sounds like Paud knows how to find TDC on the compression stroke. I would just start over and adjust both push rods but increase preload past his 2.8 turns; 3.5 to 4 turns dependng on 32 or 24 TPI. Maybe the exhuast lifter just takes longer to bleed down??
Old May 22, 2023 | 06:13 PM
  #45
paud's Avatar
paud
Thanks. S&S wants my SE pushrods to move 3 complete turns. That means compressing the S&S tappets to .125 of an inch. Harley wants their tappets to compress .100 of an inch. To me this all boils down to oil pressure and spring strength in the tappets...thats my guess. I have heard that the more compression on the tappet, the less noise in the top end. ANYway, if one Correctly adjust the pushrods and then after a few hundred miles checks the adjustment and finds when both tappets of the same cylinder are on the bottom lobe and ONE push rod can turn with your hands and the other can NOT....then what next is the question.
Old May 24, 2023 | 08:35 AM
  #46
djl's Avatar
djl
Does "bottom lobe" mean cam base circle? Is it an assumption that both lifters are on the base circle or visual confirmation? This can be tricky; a lifter can look like on the base circle but actually be on the beginning of a ramp. Both lifters must be squarely on the base circle.
Assuming both lifters are squarely on the base circle and both pushrods are adjusted the same, the situation Paud discribes is, mechanically, unlikely. Perhaps one lifter isn't bleeding down or bleeds down slower than the other. Given more time, can the OP spin the other pushrod? Maybe try this with another lifter and see what happens.
Old May 24, 2023 | 09:29 AM
  #47
Max Headflow
So if when the pushrod was originally installed, it spun freely. After riding it didn't. Pushrods really don't grow, neither do lifters. Since the pushrod is tight on TDC compression, I'd pull the pull it and check the ends. Maybe not enough lube on the end when installed and it seized in the rocker arm cup? Possibly the oiling hole in the pushrud is plugged to had some crap in it..
Old May 24, 2023 | 02:17 PM
  #48
paud's Avatar
paud
Sorry for not being clear in some places. I find I forget proper terms for things so we can all understand them. Djl, yes, I mean cam base circle. When I check again, if I can not spin one pushrod, I will wait a bit longer. I will check for possible oil blockage in pushrods, and look for any abnormality in the ends of the rods. Having said all of that, I am still trying to find how increasing the lifter pre-load affects things.
wjcbsr
Milwaukee Eight (M8)
43
Mar 16, 2023 09:43 AM
Franz_72
Engine Mechanical Topics
Dec 24, 2018 05:33 PM
bobbyjoes
Mar 14, 2014 06:14 PM
tomlescal
Exhaust System Topics
Feb 21, 2014 12:01 PM
UltraNutZ
May 9, 2012 05:14 PM
