Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I blew out 2 sets of rocker box cover gaskets on my sporty before I figured out I had crankcase pressure issues. One of the rocker box to head gaskets started weeping on the dyno too.
The stamped steel breather valves assembled back asswards??
The sporty had a plastic housing. The umbrella valve is inside. It is non serviceable.
i did the Hayden inline breather valve on it and it was a big improvement but still an umbrella valve. But the housing could be modded to make the umbrella close quicker.
Reed valves are better.
just wanted to check back in and let yall know the issue. Harley OEM gaskets are thicker than cometic. i went and got OEM harley gaskets and they sealed right up.
