Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have done a stage 3 with larger injectors to my ‘14 SGS. The only thing left is a larger TB.
I see listings for TB housings where they state transfer components from your current TB to the new larger housing.
My question is can you take the clips off the throttle control actuator and remove for transfer and the same for the throttle valve/ butterfly? All the rest I know how to do.
