I messed up.
Old Jun 30, 2023 | 11:01 PM
BEPIS's Avatar
BEPIS
Stage II
Default I messed up.
How bad? Idk.
Heres the story...
Last summer, I somehow snapped my exhaust bracket off my Basani RR II, clean. I drove a few minutes home before I had realized what happened. I got the bracket replaced, went on my merry way, and then noticed a misfire, a rattle, a weird exhaust noise. My exhaust stud snapped, sheered clean off the head.
I did what dummies do and tried a left han
ded drill bit and drilled a few millimeters into the head on the right side, near the top... Do I need a new head? Is there anyway I can take out the bolt now....?
Do I just sell the piece of junk?
Sportser 98 with a 1275 kit.
You can somewhat see it on the picture, Ill try to grab clearer ones in the near future.
You don't have to call me a dummy, I know.
Old Jul 1, 2023 | 04:25 AM
user 7209823083's Avatar
user 7209823083
There are tools to help drill that bolt cleanly, for instance Jim's 1705:
https://www.denniskirk.com/jims/exha...prd/H28222.sku
Worst case you remove the head and take it to a machine shop who can remove the bolt.
No reason to panic
Old Jul 1, 2023 | 06:07 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Getting the proper tool from Jim's is a lot cheaper than tearing down the bike to take the head to a machine shop.. Not only that who knows what else you'll run into or cause.....
Old Jul 1, 2023 | 06:58 AM
Notgrownup's Avatar
Notgrownup
Slow down, and relax first and foremost. Soak the threads with several cycles of penetrating oil. Stuff the hole with a wad soaked with the penetrating oil and let it sit for a few days . Then get the proper removal tool like a Jim’s as others have mentioned.
Old Jul 1, 2023 | 07:35 AM
Iceman24's Avatar
Iceman24
OP; No worries...this is how we learn. Get the right "tools for the job" (per above), have patience & you'll be back w/ wind in face soon. Also, as always, bike's Service Manual is your friend.
Old Jul 1, 2023 | 07:41 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Call a reputable machine shop and find out how much it will cost before you buy anything.
Old Jul 1, 2023 | 07:58 AM
BEPIS's Avatar
BEPIS
Stage II
What about the small part of the head i drilled into? Concerning? Not?
Old Jul 1, 2023 | 08:17 AM
smitty901's Avatar
smitty901
Not a hard fix for someone with experience. But if you are new to using an extractor and or drilling out and tapping it . Maybe best to let a pro do this one.
Old Jul 1, 2023 | 11:05 AM
LazySundays's Avatar
LazySundays
I would find someone with a welder. I would weld a nut on it and take it out. Might take a few tries if it's really seized in the head but I bet it's not seized and will come right out
Old Jul 2, 2023 | 05:24 AM
user 7209823083
Not
