Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
What's battery voltage? What is it when you hit start?
Doed headlight come on?
Headlight comes on as well as led display voltage is 12.8 but the start button doesn't engage starter have power everywhere except coming out of starter relay. The green/brown wire has nothing
Not an expert here. Probably either the 15A ignition or battery fuse. Or ignition switch or 30 amp circuit breaker. Is your check for power now.
