2023 CVO 121VVT Motor
Old Sep 6, 2023 | 10:58 AM
Duke4AZ's Avatar
Duke4AZ
Default 2023 CVO 121VVT Motor
I just read an article on this release and it certaily caught my attention. This has been a question of mine for some time now and I am interested in a discussion from some of our gurus on the subject of integrating a VVT (variable valve timing) into a large V-twin.
I would think there are a number of hurdles that needed to be overcome, not the least of which is realestate as both the bore and stroke increased while at the same time stuffing the vvt mechanics in the case. The other being general acceptance from the H-D V-twin community. I am not sure if Honda has the tech in their big bikes. I am going to follow that up but my impression of Honda, and maybe Indian, they are using a vvt system.
Valve train function and performance is not a strong subject for me so I am interested in 3 aspects of the vvt topic.
1. What do the smart valve train peope think are the pro's and con's of VVT as it applies to the big V-twin motorcycle engine?
2. Is it a keeper in the H-D big twin future?
3. What are the implications for the 3rd party power builder business community, cams specifically as that is where technology is integrated?
Old Sep 8, 2023 | 12:49 PM
propflux01's Avatar
propflux01
It’s already on the market and has good reviews so far. It doesn’t stick out that much on the right side. As for your three aspects,
1. it allows a better control under all driving conditions than a cam that peaks torque only in a certain rpm. Just as with your late model auto.
2. yes, I believe it is inevitable that it will become a permanent part of the HD engine future. technology is moving forward. HD has to as well to stay competitive.
3. It won’t affect them much, all the VVT does is advance and retard a given grind of cam. The aftermarket will still make cams that deliver more HP, but now without as much pralines in the RPM ranges as a cam setup does currently.
Old Sep 9, 2023 | 01:39 PM
Duke4AZ's Avatar
Duke4AZ
Originally Posted by propflux01
It’s already on the market and has good reviews so far. It doesn’t stick out that much on the right side. As for your three aspects,....3. It won’t affect them much, all the VVT does is advance and retard a given grind of cam. The aftermarket will still make cams that deliver more HP, but now without as much pralines in the RPM ranges as a cam setup does currently.
When I first saw "VVT" being the technology discussed in the article my head went to a dual cam set-up with independent intake and exhaust cam timing control, similar to what is currently used in the car industry. I was not thinking single cam phasing like what H-D is calling VVT. That simplifies the outcomes of each of the questions. It should help widen the power curves on both ends which has positve implementations for both performance and fuel economy. As to longevity in production, in theory it should be a sustainable improvement providing there is a successful implementation, ie, reliability, cost effectiveness, cultural acceptance.
Old Sep 9, 2023 | 04:59 PM
propflux01's Avatar
propflux01
Single cam VVT is what the auto manufacturers' were doing in the 90's. It worked pretty reliably then, but of course, sometimes HD can make a mess out of something easy to save a buck or two. Give it ten years or so, when Harley moves the cams above the heads!
Old Sep 10, 2023 | 07:32 AM
LazySundays's Avatar
LazySundays
Ford is using single cam VVT in the 7.3 gas engine. Some of the aftermarket builders are locking or replacing the cam phaser and turning off the VVT in the tune. This seems like the easy way out and eliminates the potential power and driveability benefits but some of these builders might just be building single purpose engines.
The R&D involved in building and tuning a cam for a VVT system is probably much higher as well. I'm no builder but I bet it needs a new level of design and tuning skills.
Old Sep 18, 2023 | 11:23 PM
Hilly13's Avatar
Hilly13
Getting into the computer to tune it might be slightly more challenging, reading the HD literature on the electronic side of it sounds like they have thrown out a challenge to the aftermarket, they also made it sound like a revelation to them that the aftermarket had been accessing the engine management in the past lol, lawyers in action no doubt.
uwiik
Engine Mechanical Topics
11
Jul 15, 2020 11:02 AM
cmashark
Fuel Moto / Jackpot Mufflers
Oct 16, 2017 06:57 PM
Iron lHorse
Jan 12, 2014 07:57 PM
Kevinm40
Apr 6, 2011 05:05 AM
schumacher
Jun 25, 2009 08:16 PM
