Rebuilt engine won't turn over
Old Feb 21, 2024 | 06:06 PM
Ohio HD's Avatar
Ohio HD
Originally Posted by Thebikerpiper
They were on, but I took them off this morning as I explored what the issue was.
I replaced the jugs and pistons with an S&S kit taking it from a 96 to a 107 and gapped & installed per the included directions. Don't recall ATM what the gap was.
No worries, the ring gap can't lock up a motor.
Old Feb 21, 2024 | 06:08 PM
MURPHCC1's Avatar
MURPHCC1
I think round mouth might disagree with you on that, you know how smart he is!
Old Feb 21, 2024 | 08:10 PM
MotoJockey's Avatar
MotoJockey
So, because I've not had this situation happen to me, if the rings ARE stuck to the cylinder walls, and the diesel fuel, and oil loosen everything up, how much damage has already occured to the cylinder walls at that point? And should it come back apart for a quick honing and ring check? I just feel after all that time/$$$/effort, I'd want my cylinder walls and piston rings damage free for a fresh rebuild.......... Just me??
Old Feb 21, 2024 | 09:16 PM
Lonewolf176's Avatar
Lonewolf176
You also seem like a fountain of knowledge. All you do is pick on Rounders.
Rounders's Avatar
Rounders
He rebuilt the entire motor, so yes he had the spacer out....... read his replies.......
I rebuilt my 09 t/c got everything back together, but the engine won't turn over. Opened up the primary and removed the chain and tensioner. The issue is the drive sprocket won't rotate. I can put up to the torque limit of 140 ft lbs on the bolt and the engine still will not rotate. It was rotating, when I assembled the engine, install pushrods, rocker plates and you have to find TDC.
​​​​​​It did sit for about three months after being rebuilt. I have fiberoptic camera and inspected the jugs through the spark plug openings and everything looks bright and clean.
Any ideas as to the issue and corrective measures?
BP
Post number 1
Did he turn it over with engine bolted together, before he let it sit for 3 months, Did he oil the walls, as part of his assembly process?
He is has never worked on a harley, just runs his mouth at people who have. I have come to realize we are in a generation that lashes out at the people who have done what they fail to do.
Old Feb 21, 2024 | 09:20 PM
Ohio HD's Avatar
Ohio HD
Originally Posted by Rounders
Post number 1
Yes, I split the case and installed an s&s flywheel, new bearings and such as I was in that far and the bike has 98k on it.
I was thinking similar and I just reinstalled the exhaust system... Isn't that wrenching?
Reply number 7....
Old Feb 21, 2024 | 09:24 PM
Rounders's Avatar
Rounders
Now we know.
Old Feb 21, 2024 | 09:37 PM
pgreer's Avatar
pgreer
I may have missed it, but was the primary chain in place and the compensator bolt fully torqued when you were adjusting the pushrods? And were the speak plugs not in the heads since you completed the pushrod adjustments?
If it was, then I agree that it's something internal and I'd start with the suggestion by DJL to add some diesel or another light lubricant and let it sit for as day or so and see if things free up. Freshly machined metal will rust quickly if not coated with oil, especially if not in a climate controlled environment.
If it doesn't free up very easily and quickly, I'd likely start disassembling things one step at a time. And I'd pull the heads to see whats going on at some point.
Paul
Old Feb 22, 2024 | 07:26 AM
Rounders's Avatar
Rounders
Has it ever rotated by turn comp when in the frame? If so, then ya I suspect stuck rings. But not sure if I would want to break them free. But if we oiled the cylinders, I am skeptical that is it. But I wouldn't be flabbergasted if it was. What was the last condition it was in, when it turned?
Old Feb 22, 2024 | 10:45 AM
MURPHCC1's Avatar
MURPHCC1
Everyone needs a hobby....
