Fuel Moto 98" Big Bore Kit
Old Mar 21, 2024 | 06:43 PM
paulmedford's Avatar
paulmedford
Originally Posted by Rounders
This was my feeling. Some guys want the power, and don't mind chasing parts. I get it, its fun. I am just to cheap. I think it would be cool to do a project that was made to handle the power. S&S cases, beefed up tranny, ect
I did a andrews 37 cam, because that was in the in cam 20 years ago, everyone was doing it. I might consider one of the 20 somethings from andrews. I did .030 head gasket on ,y 95 and 98. James makes .035 and cometic does make a .040, which I used on 103"
Again many people disagree with me on compression. But friend of mine, who is indie, said I may have lost money over the years, but these are regular people around here that riding the bike to work.
yes I trying to me keep my compression around 9.3 to 9.5 max. I have all the parts now so going and start the build soon, and ill let the OP knows how it goes, also I will try to dyno before and after the build
Old Mar 21, 2024 | 08:19 PM
Antonio Molinero's Avatar
Antonio Molinero
Originally Posted by paulmedford
ok nice, but you may need to adjust the ignition and jet size as well
ignition? That’s new to me..
jet sizing I know that
Old Mar 21, 2024 | 08:23 PM
Rounders's Avatar
Rounders
You may need an after market ignition. Is it required? I don't.. The more you bump compression the more you may need it.
GMR told me to get one, after I bought my build. I dynoed with it, didn't seem to vary much. I ran without it for awhile. I was around 9.7 compression.
Old Mar 22, 2024 | 04:31 AM
eighteight's Avatar
eighteight
Originally Posted by Antonio Molinero
ignition? That’s new to me..t
Daytona Twin-Tec is a popular option
Old Mar 22, 2024 | 05:08 AM
paulmedford
yes you may have to adjust the timing based on the cam or anything that affects the VE and compression of the build.
Old Mar 22, 2024 | 01:15 PM
Antonio Molinero
much appreciated the knowledge and help on this topic
Old Mar 22, 2024 | 01:42 PM
djl's Avatar
djl
Do not focus on static compression; it is just a number; CCP is more important. Use the Big Boyz compression calculator to input your motor data and shoot for at least a CCP of 190-195psi.
http://www.bigboyzheadporting.com/TwinCamComp.htm
Old Mar 22, 2024 | 03:54 PM
marcodarq's Avatar
marcodarq
ok, guess i'll chime in here.......
there is nothing wrong with doing 95 inch. it leaves room for later over bores if things wear out. if you go right to 97-98, there is no more room and any wear or failure will require replacing the cylinder.
that is my biggest reason for recomending the 95 kit to someone that is NOT looking for an all out performance engine, if you want all out, go as big as you can afford!
compression ratios are an opinion and experience situation to me,,,,,do you travel, do you do your own work, do you have a tech that you like to use? these are all things that I think matter, as the higher the compression goes, yes there is more power, but there is also the need for more expensive, better parts and special tuning requirements.
the Daytona Twin Tec igntion system is a great thing to have when you go above stock compression and I always recomend it.
you can build a mild 95 inch the will be high 90's hp and low 100's torque and be lots of fun to ride and still be reliable and there are lots of guys here that can tell you how to get there. FM, Scott at Hillside and Kirby down in Florida just to name a few. This can be done and have awesome results, without breaking the bank. i know, I've done it.
m
Old Mar 22, 2024 | 04:10 PM
paulmedford
correct thats exactly what I use, I went for the ccp is about 184, a little soft but I wanted it a little lower. I got the heads ported and 85cc ,and piston dome 4.6.
Old Mar 22, 2024 | 04:12 PM
paulmedford
m
this is what im going to try,. Thats why I told to op hold on let me see how is goes lol
