Anyone Running Solid Roller Lifters???
Old Apr 2, 2024 | 06:14 PM
TwiZted Biker's Avatar
TwiZted Biker
But isn't that grind for a flat tappet solid and not a roller solid? I fully understand the area of the bottom of a flat tappet that will actually make the valve open sooner therefore the grind has to be different.. It won't be able to handle harsh raimps
Maybe in the automotive world, ours live or die by the rollers.
Old Apr 2, 2024 | 07:33 PM
Max Headflow's Avatar
Max Headflow
FWIW on the 2 cams shown, You likely won't see a difference in the 2 cam lobe unless you have indicator eyeballs.. I'd bet the duration between those 2 cams is quite a bit different.. The difference is going to be the ramps. The ramp is usually something larger than a hydraulic lifter to account for aluminum air cooled cylinder / case growth. Most TC cams are 0.005-8 on ramps. A solid is likely 0.015 to 0.030 (haven't run any), It's right at the beginning / ending of the lift.. What is interesting is that the solid tappet cam looks to have some mark in it.. Like maybe it was modified or lash run too loose?
Old Apr 3, 2024 | 06:48 AM
bustert's Avatar
bustert
there is plenty of info on the net. i have a write up but cannot find it but is posted on another forum. forget about heat growth as the hydraulic compensates still even with the spacers. a big plus is the pump up and collapse.
it is in the ramp up and down. maybe i can find it on the other forum and transpose to here. now if you alter the timing from straight up, the effect is more pronounced. i run a slight retard to push the power band up about 500 rpm as i run the high speed end, as far as power increase, not much to be had.
txphatboy
Engine Mechanical Topics
Apr 5, 2022 08:42 AM
TO34
Mar 8, 2012 09:04 PM
legacycycles
EVO
May 12, 2008 01:18 PM
Fatboy931
EVO
Mar 25, 2008 07:55 AM
Fatboy931
Exhaust System Topics
16
Mar 24, 2008 02:32 PM
