110 Build
Old May 12, 2024 | 07:11 PM
Rounders's Avatar
Rounders
If sending to dark horse,is there any savings with the donor engine? Other than can do it while bike is being used
Old May 16, 2024 | 08:46 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Streetglide938
So I’d like to run a 124”, and what I’ve read a lot of guys are using the stock 110” crank and bearing. I personally don’t think that is a good idea with as much work that is going on in top end. So looking to see what crank and bearings guys are using on the high compression builds and what other internals guys are using. Also I don’t know what kind of machine work will be needed in the bottom end as well. I’m not afraid to spend money on this project as I’m not in a hurry for it. I have a motor in the bike now that I’m still running but wanting to build a good big bore motor for it.
In order to get 124 with a stock cranks you'd have to bore to 4.25. I wouldn't do it and I own a 131..
jtackett1133
Twin Cam Motors
13
Mar 14, 2022 12:38 PM
renoultra
Engine Mechanical Topics
Mar 4, 2021 03:23 PM
JONNIEROCK
Sep 15, 2018 01:48 PM
rvnkontum
Mar 31, 2016 03:40 PM
Emdog
Aug 7, 2011 06:48 PM
