Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hi everyone,I've been a bit stupid. I have a 2020 fxlrs, I've been buying parts to upgrade to stage 3 for a while done cam chest etc last thing was the big bore kit. I've purchased on ebay which said it was for my bike. pn 910-0733 which I believe is for touring models, everything seemed fine until the rear barrels bottom 2 fins sit on tappet block cover. (too late to return kit now).so I'm thinking low profile tappet block covers or machine out a few mm of the fins. would this work or is there other problems that I will encounter?I know I should have double checked part numbers but I'm at where im at.any help/advise/info would be greatly appreciated, thanks in advance.
NOTE: The cylinders are NOT identical and must be installed in the correct location. The rear cylinder has additional clearance machining in the pushrod area. The front cylinder does not.
4. Cylinder Installation NOTE: The cylinders are NOT identical and must be installed in the correct location. The rear cylinder has additional clearance machining in the pushrod area. The front cylinder does not Click here
yeah..I've learned..when all else fells..read the instructions. its normally furniture thats gets me and you can recover and reassemble. this one will cost a little time.
