Lifter noise.
Old Jun 5, 2024 | 12:04 PM
kack's Avatar
kack
Default Lifter noise.
My FXE from 1978 have started to make lifter noise after half an hour of driving.
Wonder what to check first. Thans Goran
Old Jun 5, 2024 | 12:37 PM
djl's Avatar
djl
Originally Posted by kack
My FXE from 1978 have started to make lifter noise after half an hour of driving. Wonder what to check first. Thans Goran
Uhhhhhh, probably the lilfters? How about a bit more information on the bike, like mileage, modifications, etc.?
Old Jun 5, 2024 | 07:21 PM
TexasScooterTrash's Avatar
TexasScooterTrash
78 FXE came with hydraulic lifters. Previous owner may have replaced them with solid lifter which was common. Pull a pushrod tube keeper off and lift the tube. IF it's got solids, there's an adjuster on top of the lifter. No adjuster???? Time for new lifters.
Old Jun 6, 2024 | 06:27 AM
kack's Avatar
kack
The Bike is not original. Don`t know how many Miles.
The lifter looks like this.
The small piese with the spring, can i take it appart? Thanks Goran
Old Jun 6, 2024 | 07:58 AM
kack's Avatar
kack
The last ring on the spring was holding it together.
I will do a good cleaning on the lifters and test drive.
Wonder where i can buy new Lifters, with good qualite and good price. Thanks Goran
Old Jun 6, 2024 | 08:18 AM
Ohio HD's Avatar
Ohio HD
If you do need to replace the hydraulic inserts, I would look for Eastern Motorcycle lifters. Their part number is the same as the OEM number, 17920-53A.
Old Jun 6, 2024 | 10:01 AM
kack's Avatar
kack
Thank you very much. Goran
maxburner
Audio Systems
Oct 16, 2020 07:24 AM
JONNIEROCK
Dec 30, 2013 06:35 PM
SeniorChief56
Apr 8, 2012 07:28 AM
jjb
Jun 13, 2009 06:59 AM
djwhaley
May 22, 2008 05:39 PM
