Hard Start After 883 --> 1200 Upgrade
Old Aug 19, 2024 | 10:11 AM
TheCzarOfMexico's Avatar
TheCzarOfMexico
Default Hard Start After 883 --> 1200 Upgrade
I just finished installing my V-Twin 1200 jugs and pistons. It runs great with a notable power increase so I'm very happy with that. The only thing thats bugging me is it's hard to start now despite it being on the trickle charger the whole time it was down for the work. It acts like the battery is low of the starter is weak, doesn't like to turn over. The pistons are dished so the compression should be the same or similar to what it was before. Anyone else experience this?
Old Aug 19, 2024 | 11:49 AM
marcodarq's Avatar
marcodarq
what year is your bike
Old Aug 19, 2024 | 12:03 PM
TheCzarOfMexico
2010 with ~10k on it.
Old Aug 19, 2024 | 12:29 PM
Super Glidester's Avatar
Super Glidester
battery could be bad?
Old Aug 19, 2024 | 12:33 PM
TheCzarOfMexico
Thats not unreasonable. Just odd because it was fine before I took it down (about a month ago) and it's been on the tender the whole time.
Old Aug 19, 2024 | 12:37 PM
Bott's Avatar
Bott
What is the battery reading with engine off, charger not plugged in? 12.8v or higher? 12.6v says to recharge.
Say you run a voltmeter on the battery and watch the readings thru this process:
1. Static or no running says 12.8v or better.
2. Key on shows it didn't drop from 12.8v.
3. Start bike shows a drop to 11.1V.
4. Begins to idle and shows 14.4v.
5. Idles but shows 12.8v steady. This says stator is burnt out.
6.. Idles but shows 15v or higher. This says volt reg is burnt out.
Starter motor is the load test and returns to 12.8v shows it has reserve so this says battery is good.
Old Aug 19, 2024 | 01:00 PM
Super Glidester
sometimes its the simple stuff but it could be it though just coincedence with the top end upgrade Id say if the battery is 5 years old or more it may be time to have it checked tested etc.
Old Aug 19, 2024 | 01:26 PM
TheCzarOfMexico
Good plan to rule out the battery.
Old Aug 19, 2024 | 01:28 PM
TheCzarOfMexico
Yea I've only had it for a ~year but figure it has to be on its second battery at least and that would put it >= 5 years old.
Old Aug 19, 2024 | 03:03 PM
Max Headflow's Avatar
Max Headflow
1. Static or ignition off says 12.8v or better.
2. Key on shows it didn't drop less than 12.4v.
3. Start bike shows a greater than 9.5V.
4. Begins to idle and shows greater than 13.1.
5. Idles but shows less than 13.1v steady. This says stator or regulator is burnt out.
6.. Idles but shows 15v or higher. This says volt reg is burnt issue.
Starter motor is the load test and returns to 12.8v shows, it has reserve so this says battery is good.
Fixed it..
