Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm assuming you did the test with the throttle plate wide open.. That's not that high to warrant compression releases, I'm wondering what your timing tables are.. Can you post a video of it trying to start? Cold and hot..
no I didnt open the throttle plate but I cranked it til it leveled off. What I noticed when doing the test is its only the first crank thats hard. So even with no spark the first rotation was hard/slow but after that it cranked fine for ~10-15 seconds til the compression gauge stopped increasing.
if it was compression causing the issue it should have cranked slow through the whole compression test.
I got this one, pretty cheap lithium battery with twice the CCA of a normal battery but had to return it because the poles were reversed despite Amazon saying it fit.
