Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So I'm having an issue getting right with selecting and finding the correct pinion gear for my 1991 FXSTS. After a lot of research and learning a few new things I am coming up blank with what I'm looking for.
The main issue it seems is that the 90-92 softail was a "crossover" period between the earlier 89's that had a tapered shaft with a recessed gear for the nut, to the 93's and later that have no taper on the shaft
and no recess in the gear.
I cant find anywhere that has the pinion gear I need. What I'm wondering is, am I missing anything thechnically? If I cant find the OEM part #24043-90, what other options do you think I might have?
