Feuling M8 oil pump
Old Apr 6, 2025 | 01:34 AM
early times's Avatar
early times
Default Feuling M8 oil pump
If anyone is planning on doing their cam chest, upgrade to the oil pump, cam plate, installing a cam on the M8, DO NOT go with Feuling. I did, less than 500 miles ago, and today I had sumping, big time. So now I have to go in and do the job again. Im going back to the stock pump and plate. Don't drink the red cool aid. Now, they make beautiful stuff, Ive run them on Twin Cams for years, never had any issues. There's something wrong with their M8 pump and plate.
Old Apr 6, 2025 | 06:37 AM
GalvTexGuy's Avatar
GalvTexGuy
That sucks. For some reason, they do have an awfully long Troubleshooting Guide on sumping. Makes you wonder why, doesn’t it?
https://www.feulingparts.com/tech/troubleshooting
Old Apr 6, 2025 | 08:04 AM
cobra23's Avatar
cobra23
Could be an install issue. Feuling oil pumps, including the HP+ and Race Series for Milwaukee Eight (M8) engines, are designed to mate directly to the engine case with precision machining, relying on O-rings for sealing rather than a separate rear gasket. Specifically, the oil pump uses an O-ring in the scavenge port and another sub-seal O-ring on the engine case side to ensure a proper seal and prevent leaks or wet sumping issues.
However, due to customer demand and inquiries, Feuling added an optional O-ring groove to the back cover of their M8 oil pumps starting around May 11, 2021. This was in response to concerns about sealing in certain conditions—like engines with higher cylinder leak-down, poor sub-seal O-ring fitment, or looser tolerances. Feuling’s in-house testing on healthy engines didn’t show a significant benefit to adding this O-ring, but they included the groove as an option. If you choose to use it, you’d transfer the O-ring from the stock Harley-Davidson oil pump cover to the Feuling pump’s groove. This isn’t mandatory, though—it’s more of a precautionary measure for specific scenarios.
In practice, whether you need this extra O-ring depends on your engine’s condition and how well the pump seals without it. The Feuling pump’s billet construction (6061 for HP+, 7075 for Race Series) and tight tolerances are intended to work effectively with just the provided O-rings, assuming proper installation. If the pump is installed correctly—centered to the pinion shaft, with well-lubed O-rings and no damage—you shouldn’t need an additional rear gasket or O-ring beyond what’s supplied. Always double-check the scavenge port seal, as any compromise there can lead to oiling issues, regardless of an extra O-ring.
sunny7775
Engine Mechanical Topics
Feb 27, 2024 02:56 PM
Gymrat2
11
Dec 29, 2023 06:57 AM
98hotrodfatboy
Twin Cam Motors
Feb 22, 2023 03:10 PM
Sethjamto
24
Mar 24, 2021 06:17 AM
HDF Tech
Jan 30, 2006 06:30 PM
