2010 Tranny shift arm
Old May 23, 2025 | 08:35 PM
Weeboy1's Avatar
Weeboy1
Default 2010 Tranny shift arm
Just wondering. Prior to 09 it was said the rear shift arm replacement meant removing inner primary. After which there was an indent machined into the inner primary case. I can feel the indent but am unsure if the shift arm can be removed and a new one replaced without still removing inner primary. I don’t want to attempt it until I know for sure. It doesn’t appear like there is enough space but ….
Anyone confirm or deny?
mines a 2010.
Old May 23, 2025 | 09:16 PM
Roberto88's Avatar
Roberto88
On a 2010, the indent in the inner primary allows the rear shift arm to be replaced without removing the inner primary. You should be able to remove and replace it directly. Just ensure the bike is stable and you have proper access.
Jimmy Postale
Jun 13, 2020 09:49 PM
TSheff
Dec 6, 2014 08:50 AM
streetglide13
Jun 22, 2014 04:20 PM
JustDave71
Apr 14, 2010 04:40 PM
fatbob
Sep 30, 2008 08:35 PM
