Engine noise
Old Jun 1, 2025 | 09:33 AM
Guuuuns's Avatar
Guuuuns
Default Engine noise
Nice to meet you. I have a 05 twin cam. I got a noise from the rockerhead, so I replaced the rocker arm, the push rod, and the lifter all. Still, the noise. It's fine during idling, but it happens when the rpm goes up or down. Is the crankshaft or flywheel bearing a problem?
File Type: mp4
Old Jun 3, 2025 | 12:48 PM
djl's Avatar
djl
What I hear is lash in the valve train; not crank related. OEM pushrods or adjustable? What lifters?
Old Jun 3, 2025 | 05:32 PM
Max Headflow's Avatar
Max Headflow
You are getting a whirr with the rattle.. I'd suspect cam chain tensioners.
Old Jun 15, 2025 | 12:14 AM
Guuuuns's Avatar
Guuuuns
The lifter, push rod, and rocker arm have all been replaced with new OEM products. Nevertheless, the noise continues.
Old Jun 15, 2025 | 12:18 AM
Guuuuns's Avatar
Guuuuns
I have replaced both the cam chain tensioner and cam bearing, the noise is from the left side of the engine, not the cam side.
Old Jun 15, 2025 | 05:58 AM
NorthWestern's Avatar
NorthWestern
You have quite a few threads and posts about engine noises. Are these all for the same bike, and issue?
Old Jun 15, 2025 | 08:11 AM
Max Headflow
Then your primary chain is too tight.. As light as the rattle is, I'd suspect you got rocker shaft rattle... BTW, I would not use new OEM lifters (99C) , they have been known to fail.
Guuuuns
Twin Cam Motors
Apr 12, 2025 12:06 PM
Guuuuns
Twin Cam Motors
Oct 13, 2024 12:49 AM
Cohiba_Joe
Oct 26, 2020 08:17 PM
street bob 59
EVO
Aug 15, 2018 04:31 AM
olguy
Exhaust System Topics
Sep 2, 2008 06:33 PM
