Twin Cam Motors Twin Cam 1998 thru 2017
05 twincam noise
Old Apr 11, 2025 | 08:53 AM
Guuuuns's Avatar
Guuuuns
Default 05 twincam noise
Hello guys. I have a question. I replaced all cam service kits (cam chain ten, lifter, rocker arm, valve seal). I also installed the rocker lock kit. Nevertheless, the cylinder head makes noise. The noise is not before preheating, but it is after preheating. The noise is more as the RPM increases.
1.What is the problem with noise?
2. Is the engine oil circulation a problem?
Please help me with the solution. 🙏
I'll attach the video.
File Type: mp4
File Type: mp4
File Type: mp4
Old Apr 11, 2025 | 04:08 PM
djl's Avatar
djl
I hear a little bit of valve train noise but not enough to bother me. Based on the video looking into the oil tank neck, I would say oil circulation is not a problem. I have a few questions though:
I see the bike is a softail; what year?
Why did you replace the cam chest parts?
Are the replacement parts the same as the removed parts or are did you replace OEM with aftermarket?
How many miles on the motor?
What replacement lilfters?
OEM or adjustable pushrods?
Old Apr 11, 2025 | 04:28 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I hear obviously an issue maybe. Exhaust however is interfering. Put a two ear stethoscope on it to kill that exhaust. Probe head and cylinder top to bottom.
Do you hear enough bang (tap) to hurt anything? My 04 with 50k on it doesn't sound like that.
Now it did once checking the cam tensioners and made the mistake of draining oil first and bottomed lifters.
It sounded a little like that about half way past sounding like it was self destructing and OK again when I started it.
I love that shot of a electronic sequential port fuel injection in action. Ever time you shut it down, that last charge remains and if it sets, dries up and looks like oil.
Old Apr 11, 2025 | 04:53 PM
djl's Avatar
djl
"Obviously and issue maybe", come on Jackie.
Old Apr 11, 2025 | 06:30 PM
Jackie Paper
A rag muffling that exhast will help. That's the difference in those two words since the FP combined two issue. A two ear stethoscope settles the issue.
Sorry if my wording on an on line is difficult to see a big picture.
I saId nothing on your post but I hear a lot of valve train issues I think. But I perfered not to post like a rounder
It's too loud for piston slap which is deeper but both can sound similar.
Not telling you this. Just how I see and interpret it for the First Poster.
Sure as a community team, you have a lot more experience then I.
Old Apr 11, 2025 | 09:00 PM
djl's Avatar
djl
Originally Posted by Jackie Paper
A rag muffling that exhast will help. That's the difference in those two words since the FP combined two issue. A two ear stethoscope settles the issue. Sorry if my wording on an on line is difficult to see a big picture. I saId nothing on your post but I hear a lot of valve train issues I think. But I perfered not to post like a rounder. It's too loud for piston slap which is deeper but both can sound similar. Not telling you this. Just how I see and interpret it for the First Poster. Sure as a community team, you have a lot more experience then I.
Apologies not necessary, my comment was "tongue in cheek"; the comment was just a bit oxymoronic. I don't fault you for hedging a bit, always hard to diagnose a noise in a video clip. Two people listen and hear what they hear. I just don't hear anything, other than some valve train noise, to be much of a concern but I will listen again. I don't know your experience but being a community team member has nothing to do with that.
Old Apr 11, 2025 | 09:11 PM
Guuuuns's Avatar
Guuuuns
Nice to meet you, I'm Softtail 05. There's less noise in the video. There's a lot of noise in the drive. I kept making noise, so I replaced them all. I asked if the engine oil circulation wasn't enough. (24197mile, All replaced with Harley, the push rod is pure.)
Old Apr 12, 2025 | 12:06 PM
djl's Avatar
djl
Thanks for the information. It is very difficult to diagnose motorcycle noises recorded with cell phone audio. After listening to the video a couple of times, I do not hear anything alarming but do hear some valve train noise which is very common.
As for oil circulation, if you have good oil pressure and the dip stick registers close to full at operating temperature, don't worry about oil circulation; I don't believe that is a problem or contributing to the noise you are hearing.
How does the bike run now after the installation of the new parts? If I understand correctly, the motor started making a new noise which is why you replace the parts suspected of contribuing to the new noise but the noise remains; is that correct? If that is correct, I think we have to go back in time and find out more about what may have happened to cause this new noise to present. The source of the noise could be unrelated to the parts you replaced.
You did not mention the condition of the cam tensioner pads; what condition were they in and were they replaced.
Guuuuns
Engine Mechanical Topics
18
Feb 23, 2025 10:06 PM
Guuuuns
Twin Cam Motors
Oct 13, 2024 12:49 AM
Ro33
Twin Cam Motors
Nov 6, 2022 11:18 AM
Cohiba_Joe
Oct 26, 2020 08:17 PM
dvanhorn
Dec 4, 2012 09:41 PM
