rocker arm noise
Old Dec 4, 2012 | 04:29 PM
dvanhorn's Avatar
dvanhorn
Default rocker arm noise
I have a 00 1200S and did a cam change to Andrews N4 along with a 2 into1 pipe. The thing is that it now has a pecking noise that comes and goes. It had the same noise but not as loud. I've heard of a noise cam but this is strange because it's not consistent. Any ideas?
Old Dec 4, 2012 | 04:41 PM
ev0lution7's Avatar
ev0lution7
did you check your lifters... sometimes they get air in them and can be a little noisy...
Old Dec 4, 2012 | 05:58 PM
dvanhorn's Avatar
dvanhorn
The air should work it's way out while riding it. Don't seam to do it as much as it was.
Old Dec 4, 2012 | 06:00 PM
Von_Zipper's Avatar
Von_Zipper
So how much did you ride.
Old Dec 4, 2012 | 06:28 PM
dvanhorn's Avatar
dvanhorn
I have rode about 50 miles or so. Like I said it seams to be getting less as time goes on. Just kinda of worried that the oil pump may need work.
Old Dec 4, 2012 | 06:58 PM
ev0lution7's Avatar
ev0lution7
Did u change the pump drive gear when u did the cams?
Old Dec 4, 2012 | 09:41 PM
dvanhorn's Avatar
dvanhorn
No, didn't see anything wrong with it. I test fit all the gears and rotated them in the side case to check for good clearance like the directions said to.
beasleyiv
Milwaukee Eight (M8)
23
May 21, 2019 09:56 AM
JONNIEROCK
Dec 30, 2013 06:35 PM
46u
Exhaust System Topics
Oct 22, 2013 07:43 AM
rm4040
Mar 28, 2011 04:44 PM
webscrounger
Jun 8, 2007 05:41 PM
