Cylinder machine work recommendations
Old Jul 3, 2025 | 04:56 PM
marcodarq's Avatar
marcodarq
welcome, good luck.
m
Old Jul 4, 2025 | 04:29 AM
eighteight's Avatar
eighteight
Originally Posted by marcodarq
some asian ATV's have nikisil cylinders and are not ment to be bored and honed.
marco
Good call. Cylinder in pic appears to have a steel liner
Quick check with a magnet will confirm or deny
Old Jul 4, 2025 | 07:06 AM
mseawell1022's Avatar
mseawell1022
you coud also contact a company called LA Sleeve and see if they can help you.
800-822-6005
m
FYI, this company replied to my request and stated the Honda 400 cylinder could be re-bored or re-sleeved and quoted prices for both.
Thanks
Old Jul 4, 2025 | 08:23 AM
cobra23's Avatar
cobra23
I would give Zippers a call. They might have some contacts.
https://www.zippersperformance.com/
Old Jul 4, 2025 | 08:37 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Looks like a No-brainer. It's a HONDA, take it to a Honda repair shop. LOL
Old Jul 4, 2025 | 09:46 AM
Max Headflow's Avatar
Max Headflow
I doubt any Honda repair shops do the work now days but could be wrong.. You can always go there and ask. Cylinder has a cast iron sleeve so it should be bore-able. Don't need torque plates as the block is looks pretty stout. They should be able to do a valve job on the heads.
Check the local automotive machine shops... You can try the local Napa and they can probably tell you where to go..
Old Jul 4, 2025 | 10:58 AM
mseawell1022
That's is a good idea.
I live in a rural area there are simply not many if any local options. Doing a google search of Automotive Machine shops all of them are at least an hour away. There is a small shop fairly local ran by an elderly gentleman, but it has a sign on the door stating that it is closed due to a back injury.
Old Jul 7, 2025 | 05:52 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I know Scott at Hillside motorcycle machine in Martinsville New York 315-495-6650 those two stroke work.. He builds extremely high performance race drag sleds. Snowmobiles... We're in a very rural area as well so I'm sure there's nothing he doesn't work on.. Tell him I sent you..
Old Jul 7, 2025 | 07:05 AM
Rounders's Avatar
Rounders
Go to dealer and ask them if they use anyone or ask a local shop. Last time I had bike cylinders done I asked a shop and they gave me a name of shop. I suspect a shop that does bike will do most others. Can't make a living just doing bikes, I suspect. Even try asking a car mechanic if they know of a place, and just call them. But again just ask a local shop and see what they say.
I asked a big local speed shop who does all kinds of stuff, but they don't bore their own cylinders.
I suspect you will find a shop within a drive's distance that does it. Someone mentioned NAPA, another good choice,
Old Jul 7, 2025 | 02:43 PM
98hotrodfatboy
CORRECTION TO MY LAST POST...
It was supposed to say Munnsville NY..
