M8 S&S Head Breathers
Old Jan 3, 2026 | 09:42 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Forget all that work, just replace the transmission top cover with the newest configuration cover, route the breather hose overboard.
Block the breathers using solid bolts.
About 90 bucks for the cover.
Vs the cost of a rocker box gasket set (About 100 bucks) and S&S breathers 300 bucks.... 300 bucks for breathers????
And about 4 hours+ work vs 30 minutes, and a lot of money.
I have 2 M8 machines that I have set up with the new transmission cover vented overboard, head breathers blocked off with solid bolts, I have not seen a drop of oil on the end of the breather hose.
Ref:8
29400448
VALVE,ENGN BRTHR,COVER ASSY | top, with 34800071 and 34800043 (black)
$88.03 + tax
Old Jan 4, 2026 | 03:55 AM
NorthWestern's Avatar
NorthWestern
Yeah, there are some expensive head breathers out there. Feuling has a set for $400.
The trans cover is the way to go!
Old Jan 4, 2026 | 06:18 AM
rigidthumper's Avatar
rigidthumper
I'm cheap. I took the trans cover off, used a step drill to punch a hole in the right spot, & a matching hole in the gasket; inserted a
Dorman PCV Valve Grommet Dorman PCV Valve Grommet
($8 on Amazon) and a
Toyota PCV Valve Toyota PCV Valve
($20 on Amazon), and a short piece of hose to route the fumes overboard.
Old Jan 5, 2026 | 09:10 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by rigidthumper
I'm cheap. I took the trans cover off, used a step drill to punch a hole in the right spot, & a matching hole in the gasket; inserted a Dorman PCV Valve Grommet ($8 on Amazon) and a Toyota PCV Valve ($20 on Amazon), and a short piece of hose to route the fumes overboard.
@Dan89FLSTC
@rigidthumper
Curious if that method would work on a 2013 Twin Cam?? I have a very hi comp TC that could use better breathing...
Old Jan 5, 2026 | 09:11 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
@Dan89FLSTC
@rigidthumper
Don`t know, sorry.
Old Jan 5, 2026 | 05:26 PM
rigidthumper
On big breathing TC engines, I like the TMan or MegaFlo vents (Tman drills and taps a passage in the heads, Jim @ MegaFlo drills/taps a port in the rocker boxes. Either way helps.
Old Jan 5, 2026 | 06:16 PM
98hotrodfatboy
I will look into that.. thank you..
if you have contact info for them (mega flo) i would appreciate it..
Edited: I found their website.. thank you..
blacksmoke59
Welcome Area Only
15
Jun 14, 2024 07:21 AM
sbrmike
Shovelhead
Jan 27, 2024 05:52 PM
jjsohio
Jun 8, 2016 02:43 PM
enicol
Shovelhead
Jun 3, 2013 05:14 PM
geargrinder
Exhaust System Topics
Jan 11, 2008 06:02 PM
