Cam install. Is this right? Help needed
Old Jan 10, 2026 | 11:05 AM
Socalledchad's Avatar
Socalledchad
Default Cam install. Is this right? Help needed
Im replacing my cam in 2024 117. Ive only done this one other time.. Last time I removed the cam/crank sprockets and chain all together and never moved them off their location on the cam chain. For whatever reason I didn't do that this time. I took the sprockets off the chain. ...also I rotated the engine afterwards.
Im now questioning if the crank and the cam can become out of time ? If the dot on the cam sprocket is at 6 o'clock and the the dot on the crank sprocket is at 12 o'clock can the cam still be out of timing since I turned the crank randomly while having everything apart?
Any help would be appreciated
Old Jan 10, 2026 | 02:02 PM
Lonewolf176's Avatar
Lonewolf176
As long as the dots line up you're good. You have to remove the chain from the sprockets to be able to measure that the spacer behind the cam is right.
jp0469
Apr 15, 2024 03:05 PM
lonerider1960
Feb 2, 2023 09:46 PM
dmrphy03
Oct 7, 2022 08:53 PM
quigley
Exhaust System Topics
16
Sep 26, 2022 02:09 AM
20NightTrain03
Sep 13, 2007 10:59 PM
