Lifters twin cam 88
Old May 13, 2025 | 12:50 AM
grumpybastard's Avatar
grumpybastard
Question Lifters twin cam 88
So the twin cam 88 lifters are Identical to a small block Chevy? (Hydraulic)
Old May 13, 2025 | 03:26 AM
eighteight's Avatar
eighteight
Yes, they will work
Many discussions and opinions here on the subject
Old May 13, 2025 | 04:51 AM
Jackie Paper's Avatar
Jackie Paper
That's not true without a lot more detail. Few GM motors have roller hydraulic lifters.
Google..
  • Hydraulic Roller Lifters:
    These lifters use a roller to follow the camshaft and a hydraulic plunger to maintain valve lash.
  • Chevrolet Lifters:
    Some Chevrolet lifters, particularly those designed for the SB Chevy (Small Block Chevy) and GEN III/LS1/LS2/LS6 engines, are compatible with Harley-Davidson EVO and Twin Cam models.
  • Part Numbers:
    Look for part numbers like 7390-4 for EVO lifters or 850-1 for Gen III/LS1/LS2/LS6 lifters.
  • Compatibility:
    It's important to confirm compatibility with your specific Harley-Davidson engine and make sure the lifters are designed for the correct pushrod length.
Old May 13, 2025 | 08:25 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
They are not identical.
Old May 13, 2025 | 03:42 PM
roussfam's Avatar
roussfam
Man this has gone around a few times. My understanding is NO they are not the same. There's more to it than they fit.
Old May 13, 2025 | 08:21 PM
djl's Avatar
djl
At one time, the only difference was the oil hole in the piddle valve and both made by Delphi; close but not identical.
Old May 14, 2025 | 06:54 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I'm currently running comp 850-1 lifters and my well-built Dyna in my signature. Spring pressures are 170 on the seat and 360 at .600 lift and they're quiet as hell. No problems.. The entire valve train is quiet and works perfect..
Old May 14, 2025 | 07:55 AM
bustert's Avatar
bustert
there is a video on the subject by S&S.
you will have oiling issues at start up
Old May 14, 2025 | 09:28 AM
98hotrodfatboy
I will dig out my paperwork and I'm pretty sure that all the ports were very close to identical with the OEM lifters.. There is no 2 minute difference As noted in their video between S&S and going with the Comp lifters.. I don't know which ones they used but I do know that I totally took them apart and measured everything to confirm.. actually have a thread around here that I created discussing several different brands of lifters and measuring them and comparing them...
Old May 14, 2025 | 09:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted
