Is it time for a new engine?
Old Mar 11, 2026 | 06:30 PM
Peanuthead's Avatar
Peanuthead
Default Is it time for a new engine?
Back in September I had the oil pump, cams, chain tensioner guides, lifters, and pushrods replaced because my oil pump took a **** (0 oil pressure and bearings were shot). Because the weather in Ohio wasn't the greatest when I picked it up, I was only able to put 200 miles. Now, this past weekend was beautiful so I decided to fire up the Road King (05 FLHRSI for context), oil light was on and the top end is tapping. Mechanical guage shows 0 psi. She's back at the shop that did the work and I'm being told the pump is in good shape and the o-rings are fine. Any idea what might be wrong?
05 Road king FLHRSI 88CI w/62k miles.
Old Mar 11, 2026 | 10:47 PM
Max Headflow's Avatar
Max Headflow
Did they disassemble and check the pressure relief valve? Sounds like they didn't clean the oil pan.
Old Mar 12, 2026 | 05:15 AM
Slingshot383's Avatar
Slingshot383
Axtel makes a better oil pressure relief valve that bypasses into the sump and prevents the pump from cavitating which will cost oil pressure.
Old Mar 12, 2026 | 06:19 AM
Peanuthead's Avatar
Peanuthead
Max- The shop did do an oil change but not sure about the pressure relief valve.
Slingshot- I'll look into that.
I should add that the cam plate was not changed and I installed Andrews cams (don't remember which ones).
Old Mar 12, 2026 | 07:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What caused the initial oil pump failure, was it the cam chain tensioner?
Old Mar 12, 2026 | 08:10 AM
Peanuthead's Avatar
Peanuthead
Yes, they had deep grooves in them.
Old Mar 12, 2026 | 12:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Was any tensioner debris released into the engine?
Old Mar 12, 2026 | 12:22 PM
Peanuthead's Avatar
Peanuthead
From what I remember, there was not. The more I'm looking around for possible causes, I think the pressure relief valve might be stuck open.
Old Mar 19, 2026 | 04:24 PM
Peanuthead's Avatar
Peanuthead
So here's an update for everyone. Shop opened her back up, inspected everything and didn't notice anything out of the ordinary. No scars or burns, no missing or chewed up o-rings, not even one bit of forbidden glitter. They swapped the oil pump with a replacement (another Drag Specialties). Yay warranties! And a few hours ago I was told everything is fixed. Running great with plenty of oil pressure. So here's hoping i get more than 150 miles outta this pump lol.
Old Mar 19, 2026 | 05:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks for the follow up.
