Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
That is not what you need to be checking. Put the dial indicator perpendicular to the pinion shaft and rotate the crankshaft to check the runout.
When cam cover is on and checking for gear lash, rotate the crankshaft 90 degrees and check backlash again. Repeat every 90 degrees. .
Ok, I was told previously to not check run out, but to check end pay. It is easy enough to set up and do run out so I'll do that next.
