I hate HALOMAR
First, at 500 miles, the front bottom thru stud was leaking. No biggie, put copper washers on the nuts - problem solved. NOW, it's pouring out the upper rear stud as well as seeping from the seams front and back
Yes, of course I torqued everything and used enough to squeeze out everywhere and make a mess.
All Halomar is good for is sticking a gasket.. and I can do that with cheap grease.
NEVER USE HALOMAR
NEVER USE HALOMAR
NEVER USE HALOMAR
