Gasket sealer yes or no
Old Nov 19, 2014 | 02:24 PM
Inop's Avatar
Inop
Default Gasket sealer yes or no
Had an oil leak coming from the trap door gasket on my transmission. Getting ready to install the gasket and wondering what type sealer to use, or not use any at all.
Old Nov 19, 2014 | 02:59 PM
Spanners39's Avatar
Spanners39
No sealer, just a new gasket.
Old Nov 19, 2014 | 04:37 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default + 1
shouldn' be anything...
Old Nov 19, 2014 | 09:08 PM
Tee&Vee's Avatar
Tee&Vee
Not that I am contradicting our Kiwi expert but I use "the magic" on all gaskets. Permatex Anaerobic gasket maker, it's red jelly and it works on gaskets like magic hence the name. I rarely buy new gaskets, I spread the magic and reuse the older ones to great success.
Old Nov 19, 2014 | 09:18 PM
98hotrodfatboy
Default interesting
What its it, like a non stick material that preserves the integrity of the gasket?
Old Nov 19, 2014 | 09:23 PM
johnjzjz's Avatar
johnjzjz
why was it leaking in the first place - no reason found - glue it
Old Nov 19, 2014 | 09:25 PM
Tee&Vee's Avatar
Tee&Vee
Sticks like a ****.
http://www.permatex.com/products-2/p...t-maker-detail
Old Nov 19, 2014 | 09:30 PM
soft 02's Avatar
soft 02
Anaerobic for re using an old gasket but the new ones seem fine going on dry IMO.
Old Nov 20, 2014 | 04:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Hylomar.
It will not only seal, it will make gasket removal easier next time.
Old Nov 20, 2014 | 08:26 AM
92Fatty's Avatar
92Fatty
I generally do not use it on my Harley because after vibes loosen bolts the gasket and part stays in place and you lose bolt. I use leaks to tell me where I need to address.
Hylomar works good btw.
