Gently heat cycle the engine several times incrementally after reassembly before getting on it. This will allow things to stretch and confirm with each other before real pressure / stress is applied.
On inline 4s, I used copper coat on the base gaskets, but they were just a flat steel gasket, but I will go with just the gasket on the Harley. As far as seating the rings, I don't see that as any different than the inline fours, start it and let it run until it has warm up, shut it down and let it completely cool down, then repeat. Do that 4 time before riding.
It's usually a safe bet to follow the factory manual in such endeavors. The rationale being: those who design/manufacture the equipment are the experts on re-assembly procedures.
Others will have their own 'tricks', and more power to them. Perhaps they know better than the factory engineers (who are oft times constrained by the need to keep unit costs low). But generally speaking, we believe the factory on part tolerances (except .012 run-out on a twin-cam crank). So why not on re-assembly procedure?
Alan
