Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have a 1980 FXWG 1340 and according to NGK's web site they are saying that the gap on BPR5ES-11 spark plugs are supposed to be set at 0.04.
Well I set them at 0.04 and it starts good and seems to rev fine, I have not taken it for a ride yet because there is too much snow on the ground and I wanted to get some opionions on the gap from some of you guys.
Sounds to me like 0.04 is not too wide of a gap but unless someong has any helpful information I guess I will have to do a few miles and read the plugs.
What is your experience with NGK's, and what gap setting did you use.
