shovelhead
Old May 20, 2011 | 08:39 PM
Lark's Avatar
Lark
1st Gear
Default shovelhead
1983 shovelhead misfireing in back cyl
Old May 20, 2011 | 09:21 PM
jiimyc's Avatar
jiimyc
try changing to a hotter plug. if your plug is sooty black. also have your coil checked to make sure both leads are sending enough power to the plugs. they sometimes go bad on one side of the other. good luck an old biker in rhode island.
Old Jun 1, 2011 | 08:32 AM
hobobiker's Avatar
hobobiker
Check for an intake leak as well. Pretty common cause for this type of issue, especially if you know you're getting spark and it does the same thing with new plugs...
Old Jun 1, 2011 | 04:50 PM
TwiZted Biker's Avatar
TwiZted Biker
Plug wires .
74shark
Aug 24, 2013 08:10 AM
shovelhead23
Shovelhead
Jul 27, 2010 10:42 PM
MoparCain
Engine Mechanical Topics
Mar 1, 2009 01:21 PM
ethrjock
Jun 14, 2007 10:35 PM
