Installing Compensator Sprocket
Old Sep 2, 2009 | 08:16 AM
EasternSP's Avatar
EasternSP
Default Installing Compensator Sprocket
I had my 06 Road Glide torn down to install a fat tire kit. I had the primary case as part of the install procedure.
Upon putting it back together, I torqued the compensator nut to the recommended 70ft lbs, but getting it to turn another 45 degrees just wasn't working. I was using the prescribed locking block so the sprocket wouldn't turn and I was using a 3 foot breaker bar to turn the nut, but it wouldn't move any further. I had put a couple of drops of lock tight (red) on the threads as recommended in the shop manual and engine oil on the nut and spring pack facing surfaces to aid in the additional turn of the nut but it wouldn't budge beyond the torqued value. Is there something I'm missing here?
Old Sep 2, 2009 | 08:34 PM
db45's Avatar
db45
An impact wrench...... no just kiding, but I have seen it done.
Old Sep 3, 2009 | 03:03 PM
EasternSP's Avatar
EasternSP
I know it has to have been done if they have it in the manual. I've marked the nut and spring pack face so I know where the starting mark and 45 degree mark is, but I'm getting the nut to turn. I know I'm not a light weight in this, as I'm 230lbs and I'm putting quite a bit of my weight on the breaker bar.
Old Sep 3, 2009 | 06:59 PM
db45's Avatar
db45
Only thing I can think of is try another torque wrench. maybe yours is way out of calibration, and what you think is 70 ft lbs is actually 100 or something.
Old Sep 4, 2009 | 07:58 AM
EasternSP's Avatar
EasternSP
It's fairly new. I bought it Lowes about two years ago. I haven't given it much thought on how to check the accuracy of it.
Shag67
58
Sep 17, 2022 09:12 AM
Nnmharmon
Sep 30, 2014 09:51 PM
scoriden
Mar 27, 2013 04:40 PM
Deadstroke
Oct 15, 2012 11:47 AM
carcruizer1955
Apr 27, 2010 06:40 PM
