99 Road King Starting Problem
Old Oct 5, 2009 | 02:42 PM
Lozo
Guest
Posts: n/a
Default 99 Road King Starting Problem
Bike would not start. Acted like a dead battery. replaced it with new one and it started right up. Problem solved I thought. Let it run for ten minnutes or so so I could change the oil. Shut it off and tried to start again and had the same problem. It tried to turn over once (acted like the battery was dead) on second push of start button it made clattering noise. Pushed it into garage later on and tried it agin and started right up. Next morning tried to start and same problem first tried to turn over like a dead battery then clattering noise.
  1. Switched battery with one from my electra glide which is starting fine and still the same problem.
  2. Checked battery cables, all tight and clean.
  3. Removed all cables from ground on frame, cleaned and reinstalled tightly. Still nothing.
  4. Checked voltage at battery 12.79v.
  5. Checked voltage at starter 12.79v
  6. Checked voltage at battery with start button depressed 12.5v.
  7. Checked voltage at starter with start button depressed - drops dramatically to 1 - 2v.
Could this be the solenoid? How do I check it?
Old Oct 6, 2009 | 12:21 PM
sqdealgeorge's Avatar
sqdealgeorge
Was that new bat up to snuff fully charged ? Does it sound like a jack hammer when you hit the start button ? Is the bat replacement an HD ?
Old Oct 6, 2009 | 07:07 PM
Lozo
Guest
Posts: n/a
New battery was fully charged and from hd dealer. Also switched it with my electra glide battery that starts fine and still the same problem. The clattering is loud (like jackhammer).
Old Oct 8, 2009 | 12:24 PM
sqdealgeorge
Take the cover off the solenoil (starter ) see the condition of the plunger contact area
Nitro Joe
Electrical/Lighting/Alarm
May 4, 2018 04:25 AM
Rabbito
EVO
Sep 4, 2014 06:46 PM
gulfbird
Apr 5, 2013 06:45 PM
Asuperglide
EVO
Sep 15, 2011 07:53 PM
1986FXST
EVO
Aug 24, 2008 08:50 AM
